The Bosch Endurance holesaws feature sintered carbide teeth. These ultra hard teeth give them up to twenty times the working life compared to their Bi-metal equivalents. The holesaw’s teeth are individually welded, making the whole thing extremely durable. The technology ensures higher temperature resistance when drilling into hard and abrasive materials. These holesaws will drill into wood, plasterboard, bricks, plastics, metal, non-ferrous metal, stainless steel, fibreglass, MDF, other abrasive materials, ceramic tiles and even hardened screws and nails. You can use these holesaws with any suitable corded or cordless drill. Bosch Endurance holesaws are iIdeal for heavy duty applications where BiM holesaws aren't man enough. The maximum depth of cut is 60mm. In common with other Bosch holesaws, the Endurance range uses the Power Change Plus arbor (supplied separately),a single arbor fits all 20mm to 64mm diameter holesaws.The holesaws simply click into the arbor, changing from one size to another takes a fraction of a second; no tools required just click and go.
Endurance holesaws, 20 times longer working life compared to Bi-metal
Drills stainless steel, fibreglass, MDF, hardened screws and nails
Suitable for drilling hard and abrasive materials
Individually welded, sintered carbide teeth
Use with any suitable corded or cordless drill
Maximum depth of cut is 60mm
Fits the Power Change Plus arbor (supplied separately)
