Bosch Carbide Riff Grout & Abrasive AVZ 32 RT4 (Starlock)
104801
£12.49 £10.41
In stock
- get it tomorrow, Thursday 13th Aug, order within and choose Premium delivery. Delivery info
  • Bosch Starlock Carbide-RIFF sanding finger, coarse sanding
  • Sand wood, wood-plastic composite and epoxy including decking
  • Ideal for sanding paint in tight places (e.g. shutter louvres)
Customers Also Bought
Total: £53.48
The Starlock AVZ 32 RT4 abrasive finger allows you to sand in narrow gaps and tight corners. Its pointed tip easily reaches into confined areas other sanding methods cannot. The blade is only 1mm thick, enabling you to sand in narrow openings and slots.
The sanding finger is effective for removing paint, varnish and plaster or sanding plastic composites and epoxy. The Starlock Carbide-RIFF sanding finger is fantastic for sanding paint in tight gaps, sanding parquet varnish in hard to reach areas and ideal for sanding wood, wood-plastic composite and epoxy. This makes it well suited for sanding shutter louvres, in between heating pipes and on decking. The finger has a coarse carbide 40-grit abrasive coating, providing rapid stock removal. The open-coat carbide grit offers a high wear resistance, extra long life and is less prone to clogging. Width: 32mm, Working depth: 50mm
The Starlock fitting makes it compatible with tools taking Starlock, Starlock Plus and Starlock Max and multi-tools with OIS fitting.
  • Sand parquet varnish in between heating pipes
  • Long life with carbide grit coating
  • Thin profile for sanding, narrow gaps or slots
  • 40-grit abrasive for fast stock removal
  • For removal of grout, paint, mortar/tile adhesive
  • Open-coat to minimise clogging
  • Width: 32mm, working depth: 50mm
  • Compatible with all oscillating multi-tools (Starlock, Starlock Plus and Starlock Max) and multi-tools with OIS fitting
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolYouTubeThe logo for YouTube
