This unique saw features Bosch’s 'Axial-Glide'system, which provides the smoothest and most precise cutting action of any mitre saw on the market today. Rather than using guide bars, the GCM 12 GDL features vertical and horizontal hinged arms with sealed bearings. The arrangement guarantees a maintenance-free, super smooth and highly accurate action.
In addition, the design saves space. You do not need to allow for guide bars projecting to the rear and as the controls for setting mitre and bevel cuts are at the front of the machine; you can position the GCM 12 GDL against a wall. The saw has a large cutting capacity and wide ranges of both mitre and bevel angles. A laser projects a dual line defining each side of the kerf for precise line-up before cutting. A depth of cut limiter allows you to groove or rebate.
The table has pull out material supports right and left, with stops for repeat cuts. The back fence, with a total length of 1,016mm offers maximum work support. The Axial-Glide system locks for transport.
Bevel Angle Range 47 - 0 - 47
Dust Extraction 41 mm Outlet
Mitre Angle Range 52 - 0 - 60
Overall L x W x H 673 mm x 822 mm x 686 mm
Rating Trade/Professional
Spindle Lock Standard Feature
Blade Diameter 305 mm
Sound Power Level LwA [Uncertainty K] 106 dB(A) [3.0 dB]
Blade RPM 3,800 rpm
Sound Pressure Level LpA [Uncertainty K] 93 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] <2.5 m/s² [1.5 m/s²]
Motor Power 2,000 W
Voltage 230 V
EAN Barcode 3165140584920
