PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
23.9% APR (variable)
Purchase interest rate
23.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
Spread the cost of orders up to £15,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £15,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
Package comprises the GCM 12 GDL Mitre saw and the GTA 2500 W gravity rise mitre saw stand
GCM 12 GDL mitre saw
A unique saw with a very special 'Axial-Glide' system that gives the smoothest, precise cutting action of any of the mitre saws on the market today. Guided by means of a glide arm, mounted on sealed bearings and made from robust die-cast aluminium, it is maintenance-free and guaranteed to be smooth and accurate running for a lifetime of cutting. It has large capacities and a wide angle range plus dual laser-line for precise line-up before cutting and groove function. The machine saves space as it can be positioned against a wall. All controls are at the front and the scales and positive lock handles make setting the machine easy. Fitted with integrated material supports right and left of the main table, it has a back fence with a total length of 1,016mm to give maximum work support. The glide system is lockable for transport.
GTA 2500 W gravity rise stand
Combines transport without the need for lifting, working with full support of workpieces beyond a machine base and storage. It is also very quick and easy to set up and breakdown. Two universal tool mounts allow a mitre saw to be secured (other similar items could be made to fit), whilst built into both ends of the top are adjustable supports with repetitive stops enabling long pieces of wood to be supported safely while cutting. The tubular stand construction gives a very sturdy working base, once folded it resembles a sack truck fitted with two 8" pneumatic tyres that make transporting, even over rough ground, a simple job. In set-up two levelling feet ensure stability. Supplied with 60T TCT saw blade and quick clamp
This applies to all professional blue power tools and measuring instruments from Bosch. The warranty excludes high-frequency tools, production cordless screwdrivers and pneumatic tools, supplied accessories, battery packs and chargers.
