Spread the cost of orders up to £15,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £15,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
A package of the GCM 12 SDE mitre saw and sturdy GTA 2600 legstand.
The GCM 12 SDE has a massive 120mm by 400mm maximum cutting capacity. The bevel and mitre cutting facility on both sides has indents at common angles. A laser line projects the cut line across your workpiece. Pull-out extensions on both sides of the table support longer workpieces. Dual dust extraction ports help keep the work area clean. Two outstanding features are the variable speed for cutting a wide variety of materials and an SDS nut for easy tool free blade changes.
The GTA 2600 legstand has tool mounting clamps for fast secure connection of the saw to the stand. Adjustable work supports are fitted left and right; these are height adjustable and can be extended to the required length for total work support. The legs have rubber end caps and one has 30mm adjustment for uneven floors; the legs are locked into position in use and can be folded easily for transport. The two tool clamps supplied can be fitted and left attached to the saw when not on the stand or can be mounted to other machines so these can be attached to the stand also.
This applies to all professional blue power tools and measuring instruments from Bosch. The warranty excludes high-frequency tools, production cordless screwdrivers and pneumatic tools, supplied accessories, battery packs and chargers.
