For our latest updates about delivery and stores, click here
£441.92 £368.27
Out of stock
  • Bosch GCM 8 SDE 216mm Slide Mitre Saw
  • Variable speed for cutting wide variety of materials
  • 2 dust extraction points for greater efficiency
Customers Also Bought
Total: £508.94
This package deal comprises a Bosch GCM 8 SDE 216mm slide mitre saw and an Axminster Trade site mitre saw stand.
The GCM 8 SDE Professional is compact and portable, weighing just 18.5kg. Variable speed control, from 3,500 to 5,000rpm, allows you to cut a wide variety of materials from wood to metal or plastics. The saw comes with an SDS blade-locking nut. Blade changes are quick and simple, without any additional tools. The ability to change the saw blade so easily, to suit different materials, means work becomes more efficient and your blades last longer. The saw will cut bevels up to 47°, and has indents at 22.5°, 30° and 45° for ease of setting. The positioning of the bevel-locking lever on the right-hand side next to the bevel scale, simplifies the operation.
Dust extraction takes place from 2 points, one above the blade through the guard and a second directly behind the blade. Fitted to the saw arm with a long aperture, this second point efficiently captures the debris. A depth-stop allows you to cut trenches or tenons.
The GCM 8 SDE mitre saw includes a laser-projected cutting line, transport handle and side extensions on the left and right to support longer workpieces.
Axminster Trade Site Mitre Saw Stand
The Axminster Trade site mitre saw stand has rapid clamp tool mounts, allowing fast, easy and secure mounting of all brands of mitre saws, chop saws and most benchtop tools. Both material support rollers, feature flip-up stops for repeat cutting to length.
The quick release legs make setting up fast and taking down easy. The legs are telescopic to allow height adjustment or to be set properly on uneven ground on site. The non-marring feet will not scratch or mark floors. 200mm diameter rubber wheels easily deal with rough ground and kerbs.
The stand folds for transportation making it perfect for use from the van or in a small workshop.
  • Laser projects cutting line
  • Large crosscut capacity 70 x 312mm
  • Indents at common angles for ease of setting
  • Mitre angles up to 52° (left) and 60° (right)
  • Bevel cuts up to 47° left or right
  • 3 year warranty available (registration required)
  • Axminster Trade Site Mitre Saw Stand
  • Universal mitre saw stand for site or workshop use
  • Made from welded steel tube, powder coated for long life
  • Folding, telescopic legs for height adjustment
  • Twin support rollers with flip-up stops for repeat cuts
  • Large rubber wheels and grab handle give easy mobility, no need to carry
  • Twin quick clamping mounts can stay attached to the mitre saw
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolYouTubeThe logo for YouTube
