Bosch
Bosch GHO 12V-20 Brushless Planer 12V (Body Only)
SKU: 104399
£209.98
£174.98 Excl. VAT
  • Ergonomic design, well balanced for one hand use
  • Similar in size to an equivalent hand plane
  • Precise depth control, maximum depth 2mm
  • 17mm rebate cutting capability
  • Brushless motor, highly efficient for increased runtime
  • Left or right dust extraction for convenience
  • Double edged TC reversible blades
  • 3 year warranty available (registration required)
The GHO 12V-20 cordless compact planer from Bosch is uniquely similar in size and weight to an equivalent hand plane. The ergonomic design and relatively small size make it easy to use one handed. The grip puts your hand in an ideal balanced position for good control and comfortable handling. The highly efficient EC brushless motor provides the benefits of extended battery runtimes, increased power transmission and a long maintenance free service life. Machining the main planer block housing from a solid block of aluminium adds to the tool’s durability.
The maximum cutting depth is 2mm, optimised for depths of up to 1mm, with a maximum planing width of 56mm. The GHO 12V-20 can cut rebates up to 17m deep. The blades are long lasting tungsten carbide and reversible. Dust extraction is switchable, left or right, to suit the planing direction; you can also use a dust bag.
The GHO 12V-20 is fully compatible with all Bosch Professional 10.8/12V Li-ion batteries and comes with a blade. This is a body only machine supplied without batteries or charger.
Battery Voltage 12 V
Rating Trade/Professional
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 79 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] <2.5 m/s² [1.5 m/s²]
Web Attribute Set Cordless Planers
EAN Barcode 3165140866606
