This is a clean, fast, precise cutting planer and being cordless will go almost anywhere without a cable to restrict it. It takes the hard work out of hand planing and is powered by an 18V Li-Ion battery for a powerful cut. Depth is adjustable up to 1.6mm with a rebate depth of 0-8mm, the planing width is 82mm and the machine is supplied with a special TC reversible woodrazor blade that can be replaced in seconds. Motor is braked for safety; chip clearance is to left or right, the choice is yours.
As part of the Bosch 18V professional Li-Ion family of tools, it is supplied as a body only so that you can utilise batteries from the other tools in the family. Bosch Li-Ion battery technology is premium quality for the best possible battery life and runtime; tool and battery talk to each other as fitted with electronic cell protection (ECP).
Part of the multi-brand AMPShare battery system, offering the flexibility to switch between tools and brands with compatible batteries. AMPShare batteries make it easy for you to use 18V tools from different brands using the same battery. AMPshare technology is based on the Bosch Professional 18V System, and now includes many leading European brands and is growing. AMPShare batteries are fully compatible with all tools within this multi-brand alliance including Fein and Bosch Professional 18V tools and chargers all the way back to 2008.
Supplied with L-Boxx storage case.
Cordless, powerful, compact and well balanced
Part of the Bosch 18V Li-Ion family
Fast, clean, precise cut, 82mm width
Depth adjustment, max 1.6mm, rebate 8mm
Woodrazor TC reversible blade, change in seconds
Left or right hand chip clearance
Body only, utilises batteries from other tools in the family
This applies to all professional blue power tools and measuring instruments from Bosch. The warranty excludes high-frequency tools, production cordless screwdrivers and pneumatic tools, supplied accessories, battery packs and chargers.
