Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Bosch GKF 600 Router (1/4") - PACKAGE DEAL
  • Includes a great set of 4 bearing guided router cutters
  • Compact and easy to control - a gem to use
  • Very versatile fitted with 600W motor and 1/4" collet
  • Supplied with 3 bases to extend uses
  • Side fence with horizontal and vertical adjustment
  • Dust cowl and sub base with handle and 40mm outlet
  • Quick and simple cutter height adjustment
  • All supplied in robust case
  • Show More
£198.96 (£165.80 Ex. VAT)
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
This very compact palm router from Bosch is ideal for not only the edging of laminates but also for edge moulding, mortising and a range of other work that would benefit from a powerful but light and easy to control router. Now supplied with a kit of accessories making this machine even more versatile.
The 600W motor means that this palm router is almost as powerful as many 1/4" routers and more powerful than many laminate trimmers. This is truly a very versatile machine, with a neat compact design (overall size 94 x 190mm high) which makes it easy to handle and control, and is especially suitable for confined areas.
The machine comes with a choice of 3 bases that are simple and quick to change to suit the job you are doing, 95 x 84mm base, 133mm round base and a tilting base. For height adjustment of the cutter a lock lever releases the motor from the base allowing quick coarse adjustment; the micro fine adjuster dial can then be used to set height accurately. The quick clamp base means that the router can be used without the base and the spindle lock makes changing cutters easy. Fitted with a 1/4" collet, the 600W motor runs at 33,000rpm. Along with the 3 bases a side fence is also included; this fence can be adjusted horizontally as well as vertically for thinner work pieces. The router comes with a dust cowl sub-base with a 40mm outlet and guide handle with insulation cover for heavy use situations. Includes a great set of 4 bearing guided router cutters including 2 trimmers, 1 chamfer and an ovolo with bearing to convert to roundover cutter. This machine only accepts 1/4" collet as supplied.
Information Downloads
Promo
Specification
Specification
Collets Supplied 1/4"
Corded or Cordless Corded
Fine Height Adjuster Standard Equipment
Model GKF 600
Motor Power 600 W
Nett Weight 1.5 kg
Plunge Stroke no value
Rating Industrial
Sound Power Level [Uncertainty K] 95 dB(A) [3.0 dB]
Sound Pressure Level [Uncertainty K] 84 dB(A) [3.0 dB]
Spindle Lock Standard Feature
Vibration Cutting Wood [Uncertainty K] 4.5 m/s² [1.5 m/s²]
Cutter Speed 33,000 rpm
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
