The GKS 18V-57G Circular Saw offers 57mm maximum depth of cut. The baseplate is compatible with the Bosch FSN guide rail system for more accurate results.
A robust saw made for professionals for use on site and tough conditions. At the same time, it has many refined features. Both the main and front handle have rubberised grips for comfort and safety. There are scales to act as a guide on both the depth and angle adjustments. A bevel cut of 45° has a maximum depth of 42mm.
The front of the saw features an LED job light to illuminate the cut line. The baseplate has guide marks showing where the cut will start at 90° and when set to 45°. This powerful, cordless circular saw gives you freedom to cut wherever needed without the restriction of a power cable.
Part of the multi-brand AMPShare battery system, offering the flexibility to switch between tools and brands with compatible batteries. AMPShare batteries make it easy for you to use 18V tools from different brands using the same battery. AMPshare technology is based on the Bosch Professional 18V System, and now includes many leading European brands and is growing. AMPShare batteries are fully compatible with all tools within this multi-brand alliance including Fein and Bosch Professional 18V tools and chargers all the way back to 2008.
Supplied in a Bosch L-BOXX 238 storage case. Includes a Bosch 165mm TCT saw blade. This is a body only tool without batteries or charger.
Powerful tool for fast, accurate cuts
Fast sawing rate and long runtime for greater efficiency
Designed for every type of application on the jobsite
Electronic Motor Protection (EMP); almost impossible to burn the motor
This applies to all professional blue power tools and measuring instruments from Bosch. The warranty excludes high-frequency tools, production cordless screwdrivers and pneumatic tools, supplied accessories, battery packs and chargers.
