The Bosch GOF 20-12 router is a powerful 1/2 inch plunge router engineered for demanding woodworking router applications, including hardwood cutting, edge profiling, grooving and precision trimming. Its high-performance motor and constant speed electronics help maintain smooth, consistent cutting results even under load, making it an excellent heavy duty router for professional workshops and serious DIY users. With conveniently positioned controls, including a left-hand speed dial and right-hand lockable on/off switch, this variable speed router is designed for efficient handling and accurate routing performance.
Supplied as a robust Bosch professional router, the GOF 20-12 includes features that support precise setup and comfortable operation during extended use. The easy-access plunge lever allows quick depth changes, while the after-lock micro depth adjustment mechanism enables stepless fine adjustment for accurate routing depth. Task-specific dust extraction adaptors are provided for both surface and edge routing applications, helping keep the work area cleaner. Ergonomically angled soft-grip handles reduce user fatigue and improve control, making this woodworking power router a reliable router for joinery, cabinetry and detailed woodworking projects. Included accessories include a straight fence and a roller guide; the roller guide maintains a consistent distance from the work piece edge and is used for profiling non straight work pieces.
Bosch Professional is recognised worldwide for producing durable, high-performance power tools for trade and industrial use. The Bosch router range combines precision engineering, user-focused ergonomics and long-lasting construction, making the Bosch GOF 20-12 router a dependable choice for professional woodworkers, carpenters and joinery specialists seeking a versatile router for everyday workshop use.
Fitted with Restart protection so the router will not suddenly restart if the power is interrupted helping to avoid accidents.
Supplied with edge and surface dust extraction adaptors, edge roller guide, 1/4 and 1/2 collet sets, 17mm template guide, template guide adaptor, parallel guide and centring pin and double-head socket wrench 17/24mm.
Collets Supplied 1/4 and 1/2
Overall L x W x H 390 x 330 x 220 mm
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 105 dB(A)
Corded or Cordless Corded
Sound Pressure Level LpA [Uncertainty K] 97 dB(A)
Vibration Cutting Wood [Uncertainty K] 4.0 m/s²
Motor Power 2,000 W
Plug Fitted UK 3 pin plug
Cutter Speed 10,000 - 25,000 rpm
Model GOF 20-12
Nett Weight 6.3 kg
Plunge Stroke 80 mm
EAN Barcode 4053423332308
