Bosch GOP 12V-28 Brushless Multi-Tool in L-Boxx (Body Only)
- Ergonomic; comfortable soft grip, better control, minimal fatigue
- Brushless motor; longer battery runtime and increased lifetime
- Starlock accessory fitting; excellent power transmission
Customers Also Bought
There cannot be many power tools more versatile or useful than the Bosch GOP 12V-28 cordless multi-tool. The comprehensive range of accessories allows you to use it in many different applications. Plunge cuts, flush sawing, sanding, scraping, rasping and grout removal are all well within the GOP 12V-28’s capabilities.
The brushless motor ensures longer battery runtimes as well as a long maintenance free service life. Its compact design, slimline ergonomic SoftGrip and low weight offers comfortable working with little fatigue. It’s a true 'go anywhere, do anything' tool with no mains lead tethering you to a power socket.
The Bosch Starlock mounting system means greatly improved power transmission and allows you to secure any accessory at the optimum angle for the task in hand. The variable speed allows you to select the correct speed for the operation and material.
The GOP 12V-28 comes in a Bosch L-BOXX 102 storage case along with Starlock plunge cut saw blade (AIZ 32 APB). It is compatible with Bosch Professional 10.8V and 12V Li-ion batteries, and is supplied as body only; batteries and charger are sold separately.
- Variable speed for maximum efficiency with material and operation
- Compatible with Bosch Professional 10.8V and 12V batteries
- For carpenters, joiners, electricians, plumbers, home and site
- Allen key fitting
- Supplied with Bosch L-BOXX 102 storage case and Starlock plunge cut saw blade (AIZ 32 APB)
- Body only, batteries and charger available separately
- 3 year warranty available (registration required)
