Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Bosch GOP 40-30 MultiCutter in L-BOXX & 15 Accessories
Code: 102350
  • 400W motor, takes standard Starlock and StarlockPlus accessories
  • Rapid, tool-free accessory changes within just 3 seconds
  • Improved transmission of torque from the motor to the blade
  • LED worklight illuminates the cutting edge
  • Comfort grip for improved control and reduced fatigue
  • StarlockPlus category for faster work rate
  • Supplied in Bosch L-BOXX 136 storage case with 9 blades, 1 sanding pad and 5 sanding sheets
  • 3 year warranty available (registration required)
  • Show More
£209.96 (£174.97 Ex. VAT)
Low stock - get it tomorrow, Wednesday 3rd Jun, order within and choose Premium delivery
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We'll aim to despatch your products the same day when you order before 4pm, Monday to Friday.
  • Standard UK (5-7 day) - free
  • Premium UK (next day) - from £6
  • International - available
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
  • Bosch GOP 40-30 MultiCutter in L-BOXX & 15 Accessories
  • Bosch Extraction Set for GOP Starlock Multi-Cutter Models
  • FEIN Flexible Scraper 165 (Starlock)
  • Bosch GKT 55 GCE Plunge Saw, 2 x 1.6m Rails, Connector & Rail Bag 230V
Total: £675.21
Description
In Detail
Bosch Professional 3 Year Warranty (Registration Required)
The GOP 40-30 with its 400W motor will take both standard Starlock and StarlockPlus accessories. This powerful multi-tool gives you a wide range of cutting, sanding, grinding and polishing options. The relatively slim body and rubberised grip offers you control and comfort whatever the task. An LED illuminates the work improving the visibility of the cutting edge. The GOP 40-30 features the latest Starlock accessory mounting system. Starlock offers better performance as well as faster work progress and results that are more precise. This "Snap-in" system gives you quick, tool-free accessory changes within just 3 seconds. The system greatly improves the transmission of torque from the motor to the blade tip. No more wasted power, means faster working, minimised vibration and better results. The GOP 40-30 kit comprises the power tool plus nine blades, a sanding pad and five sanding sheets all in a Bosch L-BOXX 136 storage case.
Specification
Specification
Corded or Cordless Corded
Model GOP40-30 15 Accessories
Motor Power 400 W
Nett Weight 1.5 kg
Oscillation Rate 8,000 - 20,000 /min
Oscillation Stroke 2 x 1.5°
Pad Size 93 mm Delta
Rating Industrial
Sound Power Level [Uncertainty K] 91 dB(A) [3.0 dB]
Sound Pressure Level [Uncertainty K] 80 dB(A) [3.0 dB]
Vibration Plunge Saw Blade [Uncertainty K] 11.0 m/s² [1.5 m/s²]
Vibration Sanding [Uncertainty K] 3.0 m/s² [1.5 m/s²]
Vibration Scraping [Uncertainty K] 6.0 m/s² [1.5 m/s²]
Vibration Segment Saw [Uncertainty K] 6.5 m/s² [1.5 m/s²]
Voltage 230 V
Plug Fitted UK 3 pin plug
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
