For our latest updates about delivery and stores, click here
Bosch GOP 55-36 Multi-Cutter in L-BOXX + 36 Accessories
102772
£259.96 £216.63
Out of stock
- dispatch estimate is within 3 weeks. Delivery info
  • Supplied in Bosch L-BOXX 136 with 36 accessories:
  • 1 x Starlock Vacuum Adapter with clamping neck
  • 1 x StarlockMax Wood + Metal BIM plunge cut saw blade MAIZ 32 APB, Curved-Tec
Customers Also Bought
Total: £332.21
With its 550W motor the Bosch GOP 55-36 Professional Starlock Max™ Multi-Cutter is the most powerful multi-tool in its class. It features the outstanding StarlockMax™ Snap-In function for attaching accessories. The Starlock mounting system could not be easier, pick your accessory, position on the mount, press and away you go. If it is on your bench you don’t even have to touch the accessory, you can click it straight into the Starlock. The main advantage of Starlock is the way the connection maximises the transmission of power from tool to cutting edge. The GOP 55-36 Multi-Cutter is a fully industrial multi tool made for heavy duty applications. It is compatible with all Starlock, Starlock Plus and Starlock Max accessories.
The GOP 55-36 is supplied in a tough Bosch L-BOXX 136 with a wide range of accessories for a host of tasks, 8 blades, 1 rasp, 1 sanding pad and 25 sanding sheets Starlock vacuum extraction outlet.
  • 1 x StarlockMax Wood + Metal BIM plunge cut saw blade MAII 52 APB, Curved-Tec
  • 1 x Starlock Wood + Metal BIM segment saw blade ACZ 100 BB
  • 1 x StarlockMax Multi Material HCS plunge cut saw blade MAII 32 SC
  • 1 x StarlockMax Wood HCS plunge cut saw blade MAIZ 32 EPC, Curved-Tec
  • 1 x StarlockMax Metal Carbide plunge cut saw blade MAIZ 32 AT
  • 1 x StarlockMax Grout Carbide-RIFF plunge cut saw blade MATI 68 RT3
  • 1 x Starlock Grout Carbide-RIFF segment saw blade ACZ 85 RT3
  • 1 x Starlock Grout Carbide-RIFF sanding plate AVZ 78 RT2
  • 1 x Starlock Delta sanding plate AVZ 93 G
  • 25 x Sanding sheets: 10 x 80g, 10 x 120g, 5 x 240g
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolYouTubeThe logo for YouTube
