Spread the cost of orders up to £15,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £15,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
The Bosch GTS 10 XC table saw is a powerful and reliable machine that it is capable of handling the toughest applications, as well as performing precise and concealed cuts.
Impressive cutting power
The multifunctional table saw features a powerful 2,100 W motor with motor brake, soft start, overload protection and constant speed electronics. Its large cut capacity with high precision and extreme power makes it very popular amongst professional tradespeople as it cuts through a variety of materials with ease.
Achieve accurate results
Tool-free lowering of the riving knife allows you to make concealed cuts. The self-adjusting parallel guide ensures that you always achieve precise results while the Pre-Cut Locator ensures you accurately mark the cut.
A highly versatile machine
Thanks to the integrated slide carriage, table widener and table extension, the table saw can be used for a wide range of applications. The integrated sliding table is designed for workpieces up to 355mm and an integrated rear outfeed supports longer workpieces. There’s also integrated carry handles in the table top for easy transportation.
Safety comes first
For added peace of mind, safely store the saw blade, assembly tools and accessories directly on the housing. Well-placed dust extraction port at the back of the machine ensure efficient dust extraction. Finally, there's a new on/off switch with emergency shut-off lever.
Large cut capacity with high precision, constant electronics and extreme power make this 254mm saw a winner. The integrated slide carriage, table widener and table extension enable expansion for workpieces in a variety of sizes. Large support surfaces ensure safe and comfortable sawing. The 2,100W motor has a brake, soft start, overload protection and constant speed for whatever material you are cutting. Expanding worktop gives up to 635mm width and at 90° 79mm depth. The rip fence is fitted with the Bosch self-aligning Squarelock™ for precision every time and the integrated sliding table with mitre fence will handle work up to 350mm. There is on-board storage for cables, blades and other accessories, so you have everything to hand. Integrated handles on the machine table top allow for easy transport. Supplied with 24T tungsten tipped saw blade, mitre fence, push stick and dust adaptor.
This applies to all professional blue power tools and measuring instruments from Bosch. The warranty excludes high-frequency tools, production cordless screwdrivers and pneumatic tools, supplied accessories, battery packs and chargers.
