Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 3-5 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Bosch GWS 18V-10SC Angle Grinder 18V 8.0Ah ProCORE
Code: 106396
  • Equivalent to 1,000W corded with 8.0Ah ProCORE battery fitted
  • EC brushless motor for long run times and long service life
  • Compatible with Bosch Simply Connected
  • Make adjustments and personalise tools with Bosch Toolbox app
  • Easy disc change with Quick-lock nut
  • Supplied with:
  • 2 x ProCORE 18V 8.0Ah batteries
  • GAL 18V-160 C Professional quick charger
  • GCY 30-4 Bluetooth Module
  • Anti-vibration auxiliary handle
  • Backing flange
  • Quick-lock nut
  • Protective guard
  • L-BOXX 136
  • Show More
£491.76 (£409.80 Ex. VAT)
In stock - delivered direct from the manufacturer. Delivery time is approximately 1 week.
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
Dropship products are usually readily available and despatched directly from the manufacturer using the best delivery service available. Despatch times can vary between manufacturers and delays may occur should stock become unavailable.
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
Bosch Professional 3 Year Warranty (Registration Required)
The Bosch GWS 18V-10 SC angle grinder comes with 2 batteries: a 6.0Ah and a ProCORE 8.0Ah. This is a lot of machine; with the 125mm disc, brushless motor and powerful batteries you have the equivalent of a 1,000W corded grinder. Cordless tools free you of the limitations of a connection to a fixed power source. The brushless motor delivers maximum power, extended run times and is maintenance free.
The GWS 18V-10SC features Drop Control, KickBack Control, and an intelligent brake system, which together provide you and your machine with maximum protection. In addition, it comes complete with the GCY 30-4 Bluetooth module, which allows you to personalise your tool settings using the Bosch Toolbox app.
Supplied with two ProCORE 18V 8.0Ah batteries, GAL 18V-160 C Quick charger, GCY 30-4 Bluetooth Module, Anti-vibration auxiliary handle, Backing flange, Quick-lock nut, Protective guard and L-BOXX 136.
Promo
Specification
Specification
Batteries Included 2
Battery Capacity 8.0 Ah
Battery Type Li-ion
Battery Voltage 18 V
Bore Size 22.2 mm (7/8")
Corded or Cordless Cordless
Disc Diameter 125 mm
Model GWS 18V-10SC
Nett Weight 2 kg + battery
Rating Industrial
Sound Power Level [Uncertainty K] 90 dB(A) [3.0 dB]
Sound Pressure Level [Uncertainty K] 79 dB(A) [3.0 dB]
Spindle Thread M14 x 2 mm
Vibration Grinding [Uncertainty K] 6.0 m/s² [1.5 m/s²]
Vibration Sanding [Uncertainty K] 3.5 m/s² [1.5 m/s²]
Disc Speed 4,500 - 9,000 rpm
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
