Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 3-5 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Bosch High Pressure Laminate Saw Blade 190mm x 56T
Code: 106997
  • Developed for cutting high pressure laminate board
  • Robust blade for working with abrasive materials
  • HLTCG teeth for smooth cuts and chip-free finish
  • Extra-hard teeth from highly durable tungsten carbide
  • Special anti-friction coating also prevents corrosion
  • Anti-vibration slots for smooth cutting and noise reduction
  • Suitable for plunge and handheld circular saws
  • Show More
£40.37 (£33.64 Ex. VAT)
Low stock - get it Saturday 6th Jun, order within and choose Premium delivery
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We'll aim to despatch your products the same day when you order before 4pm, Monday to Friday.
  • Standard UK (3-5 day) - free
  • Premium UK (next day) - from £6
  • International - available
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
A circular saw blade designed and manufactured primarily for cutting high pressure laminate (HPL) boards (compact laminate board, solid phenolic board) such as Trespa and similar brands. HPL boards are becoming increasingly popular for use as countertops and wall panels. Although HPL cuts like hardwood, it is more abrasive, requiring a high performance blade.
The Bosch HPL saw blade is compatible with plunge and handheld circular saws. The blade features HLTCG (High-Low Triple Chip Ground) teeth for smooth cuts with a clean chip free finish. The blade's unique extra-hard Microteq teeth are manufactured by Bosch from highly durable carbide grains. The performance is further enhanced by the blade's special coating that reduces friction and prevents corrosion. In addition, specially designed anti-vibration slots ensure smooth cutting, considerably reduce noise and significantly reduce vibration.
Specification
Specification
Blade Diameter 190 mm
Bore Size 30 mm
Hook Angle
Kerf 2.6 mm
Model EX TR H
Plate Thickness 1.6 mm
Teeth 56
Tooth Format HLTCG
Maximum RPM 10,000 rpm
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
