Bosch Impact Control Screwdriver Bits Mixed 65mm (8)
- 8 x 65mm long, Double ended, impact 1/4" hex bits
- Supplied in Pick and Click system holder
- Specially heat treated torson zone, 10 x life of standard impact bits
This set of eight bits comes in a Bosch Pick and Click system holder, which keeps the bits secure when not in use. The holder can be used alone or easily clicked into the Bosch Pick and Click Cases M or L for replacement or replenishment.
This set comprises eight double ended, 65mm long bits with 1/4" hex shanks. Comprises: PH1-PH2 - PH2-PH3 - PH2-PZ2 - PH2-PZ2 - SL1X5.5 - T15-T20 - T15-T20 - T25-T30.
These Bosch Impact Control double ended bits are as tough as it gets. The bits are fully impact rated and suitable for use in high torque impact drivers. They will last up to ten-times the longer than standard impact bits.
The bits are S2 Modified Steel with an extended torsion zone, which absorbs peaks in torque, greatly reducing breakage.
Bit Length | 65 mm |
EAN Barcode | 3165140851343 |
Model | Bosch Impact Control Screwdriver Bits PZ2 25mm (8) |
- Standard Delivery* - £1.99
