The Bosch 5 Piece Cutting Set is a versatile accessory kit designed for professionals who need reliable cutting and plunge-cutting performance across a range of materials. Ideal for use on stainless steel pipes and profiles, wood containing nails, and drywall materials, the set provides the flexibility required for renovation, installation, and maintenance applications.
Featuring Bosch's Starlock Snap-In mounting system, blades can be removed and replaced in as little as three seconds without the need to touch the accessory. The innovative 3D, tight-fitting connection between the machine and blade ensures maximum power transfer, helping to deliver efficient cutting performance and precise results.
The set includes four plunge-cut blades for a variety of cutting tasks, along with a grout segment blade for removing grout and undertaking renovation work, making it a practical addition to any professional multi-tool kit. The blades will fit Bosch, Makita and Fein (10mm) multi-tools and others using the Oscillating Interface System (OIS™) and Starlock fitting which ensures a secure fit with maximum power transfer
Web Attribute Set Oscillating Multi-Tool Cutting
EAN Barcode 4059952629483
