A great addition to your tool kit, removing waste fast as well as giving a good even finish. It can be used across the grain for fast waste removal and along the grain for a fine finish; by working through the grits, excellent results can be achieved. If you have used belt sanders in the past you will welcome the addition of an automatic belt centring system with rapid belt change, making it high on the list of useful sanders for the home user/light tradesperson. The belt size required for this product is 75 x 533mm and the usable sanding area is 76 x 165mm. Fitted with a Bosch micro dust system filter box.
Fast and effective sanding
Coarse and fine sanding on flat areas
Use with and across the grain to flatten boards
Sanding surface of 76 x 165mm
Fitted with micro dust box sanding filter
Belt size 75 x 533mm
Bosch DIY 3 year warranty available (registration required)
This applies to all DIY power tools, garden tools or measuring tools from Bosch. This tool comes with a FREE two-year warranty, to extend your warranty to three years, simply log into MyBosch. and register your tool within four weeks of purchasing it.
Extended warranty includes: repair service, pick-up and returning your defective device for free. Warranty services are all provided by Bosch directly.
