Bosch PMF 220 CE Multi-Tool (Starlock)
- 220W powerful multifunctional tool
- Oscillating action with variable speed
- Takes the full range of Starlock accessories
Customers Also Bought
The PMF 220 CE Multi-Tool features the latest Starlock accessory mounting system. The Starlock offers better performance as well as faster work progress and results that are more precise. This system gives you quick and easy accessory changes. A magnet holds your accessory in place whilst you secure the fixing bolt. The system greatly improves the transmission of torque from the motor to the blade tip. No more wasted power, means faster working, minimised vibration and better results. Sawing, sanding, cutting and scraping, the PMF 220 CE is a true Multi-Tool with so many uses. The 220W motor and variable speed give you all the power and control required to drive a wide range of accessories. For example, you can saw close to the edge of a wall when removing the bottom of a skirting board to fit laminate flooring. Cutting pipes in situ, plunge cutting in plasterboard for fitting socket boxes, removing wall tiles or cutting rot from a windowsill are all within the scope of the PMF 220.
The machine comes complete with a bi-metal segment saw blade for wood and metal 85mm (ACZ 85 EB), a Delta sanding plate 93mm (AVZ 93 G), Delta sanding sheet set (2 each of 60, 120 and 240 grit sheets), an HCS plunge cutting saw blade for wood 32 x 40 mm (AIZ 32 EPC), Hex key, carry case and a 4-stage depth stop for segment saw blades.
- Sawing, cutting and sanding in one machine
- Suitable for repairs, renovation and awkward tasks
- Bosch DIY 3 year warranty available (registration required)
