Bosch AIZ 32 AT Carbide MetalMax Plunge Cut Blade (Starlock)
- For all metals and abrasive materials
- Hardened screws, nails and stainless steel (INOX)
- Fibreglass, epoxy, plasterboard etc.
- Tough blade with wear resistant, long-life edge
- Reinforced mount with anti-vibration slots
- Clean and precise working
- Blade width 32mm, cutting depth 40mm
- Starlock fitting for maximum power transfer
Bosch BiM C-Tec Japanese Style Plunge Cut Blade (Starlock) 32mmFrom £13.38 £11.15
Bosch AIZ 32 EPC C-Tec HCS Plunge Cut Blades (Starlock) (Pkt 1)From £10.38 £8.65
This tungsten carbide (TC) blade will cut all metals and abrasive materials plus hardened screws, nails and stainless steel (INOX), fibreglass etc. One of the toughest blades around, it has a reinforced mount with anti-vibration slots for clean, precise working. The TC tooth ensures an extra long life; 30 times longer lifetime when compared to a standard BIM or HSS saw blade. The tapered base body reduces jamming of the base body. Blade width 32mm, cutting depth 40mm.
This blade is suitable for Bosch, Makita and Fein (10mm) multi-tools and others using the OIS and Starlock interface which ensures a secure fit with maximum power transfer.
EAN Barcode | 3165140710169 |
