Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Bosch Tiling Multi-Tool Accessory Set (Starlock)
Code: 211273
  • Bosch 'Tiling' set
  • For cutting, trimming, filing and scraping
  • Cutting/removal of adhesive,sealers,epoxy & plaster etc
  • Fits Bosch and Fein Multi Tools
  • 1x Carbide RIFF segment saw blade ACZ 85 RT3 for tile cutting and removal
  • 1x Carbide RIFF sanding plate AVZ 78 RT2
  • 1x HCS scraper ATZ 52 SC for removal and cleaning residue
  • 1x BIM plunge-cutting saw blade AIZ 20 AB for metal and wood cutting
  • Starlock fitting for maximum power transfer
  • Show More
Save £9.96
Last Few
NOW £34.00
Normally £43.96
(£28.33 Ex. VAT)
Out of stock
Sorry, this product is no longer available.
See Alternative Options
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
The Bosch 'Tiling' accessory set for multi-tools, the set is made up of 4 Swiss made blades for tile cutting and restoration, removing a broken tile or grout without damage to surrounding tiles is simple with this set. Able to cut non ferrous metal, grind mortar and remove adhesive it is also a good general use set of accessories. Blades supplied: Carbide RIFF segment saw blade ACZ 85 RT3 for tile cutting and outer materials such as plaster and epoxy, Carbide RIFF sanding plate AVZ 78 RT2 for grinding removal of adhesives and fillers, HCS scraper ATZ 52 SC for removing paint, sealant and adhesives and a BIM plunge-cutting saw blade Metal AIZ 20 AB for wood and metal cutting, offset to cut flush to the surface, pocket cut straight into a surface as well as cutting off pipes, aluminium and uPVC profiles.
Suitable for Bosch and Fein Multi Tools and others using Starlock or the Oscillating Interface System (OIS™). Starlock ensures a secure fit with maximum power transfer.
Promo
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
