The working face of the X-LOCK Grinder Flap Disc is zirconia alumina, a semi-friable aluminium oxide. This grit is particularly hard wearing and long lasting in metal finishing applications. The backing is a resilient and robust plastic plate that ensures full use of the abrasive.. These discs are ideal for cleaning, smoothing and processing stainless steel, cast iron, ferrous metasl, sheet metal and alloys etc.
Although these Flap discs feature the X-LOCK fitting they are fully compatible with any conventional 125mm angle grinder with a standard M14/22.2mm (7/8") spindle. You can use them in exactly the same way as your normal discs, with the added benefit of Bosch professional performance. Used on an X-LOCK machine these discs simply click into place without the need for a locking nut or any additional tools. The Flap discs are just one option out of the large X-LOCK angle grinder accessory range.
