Bosch X-LOCK Multiconstruction Thin Cutting Discs
From £1.48 £1.23
  • Compatible with conventional grinders with M14/22.2mm spindle
  • Cuts ceramic tile, marble, fibreglass, reinforced plastic and more
  • Excellent results in a variety of applications and materials
Customers Also Bought
The Bosch X-LOCK Multi Material Cutting Disc, like the Bosch Multi Construction drill bits, give you excellent results in a wide variety of applications and materials. You only need purchase one cutting disc rather than several different types. The X-LOCK Multi Material Cutting Disc will give you precise, straight cuts in steel, stainless steel, non-ferrous metal, stone, soft brick, ceramic tile, marble, fibre glass and reinforced plastic. One disc does it all, negating the need for disc changes every time a different job comes along of cutting mixed material. The discs are only 1mm thick so help minimise strain on your angle grinder's motor. Choose from 115mm and 125mm diameter.
Although these Multi Material Cutting Discs feature the X-LOCK fitting they are fully compatible with any conventional angle grinder with a standard M14/22.2mm (7/8") spindle. You can use them in exactly the same way as your normal discs, with the added benefit of Bosch professional performance. Used on an X-LOCK machine these discs simply click into place without the need for a locking nut or any additional tools. The Multi Material Cutting Discs are just one option out of the large X-LOCK angle grinder accessory range.
  • Economic, one blade to do most jobs
  • Ideal when cutting mixed material
  • Only 1mm thick produces fast results
  • Quick, tool free changes with X-LOCK grinders
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTickA tick symbolTrade AccountSaving tag iconDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
