Get light exactly where you need it with the Brennenstuhl CL 1050. You can attach this clampable, 950 lumen LED spotlight just about anywhere. The sprung loaded clamp base opens to 55mm and grips onto flat or round sections. It can also stand alone on any flat surface. A ball joint allows you to adjust the tilt angle of the spotlight by almost 360° in all directions to align it perfectly to suit your needs. A choice of three levels (100% / 50% / 25%) allow you to adapt the illumination and offer up to 12-hours light on a single charge.
The CL 1050 is robust with IK08 protection (drop & impact) and IP65 protection (dust & low pressure spray-proof).
When the battery is almost empty, the floodlight flashes 5-times and the battery status indicator (5) flashes continuously. The floodlight will remain on for approximately 10-minutes before the light is switched off by the deep discharge protection function.
The CL 1050 can be used as a USB power bank to charge an external device, such as a smartphone or tablet, connected to the USB port.
Supplied with USB charging lead.
Versatile, shine a light exactly where it’s needed
Clamping base attaches onto flat or round sections
Ball joint for almost 360° adjustment in all directions
