Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Bridge City TM-1 Tenonmaker
Code: 106741
  • Achieve a precise fit every time
  • Takes the guesswork out of cutting tenons
  • A foolproof and accurate way to tight fitting tenons
  • Simple to set up, only requires two adjustments
  • Works with any cutter such as a saw blade or router cutter
  • Works every time on tenon widths from 3-50mm
  • Milled from solid aircraft grade aluminum
  • Show More
£50.50 (£42.08 Ex. VAT)
In stock - get it tomorrow, Friday 29th May, order within and choose Premium delivery
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We'll aim to despatch your products the same day when you order before 4pm, Monday to Friday.
  • Standard UK (5-7 day) - free
  • Premium UK (next day) - from £6
  • International - available
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
The Bridge City Tools TM-1 Tenonmaker is a diabolically simple tool which takes the guesswork out of sizing the tenon and results in a precise fit. It acts as a flip stop, requiring only two adjustments. One for the saw blade kerf and the other being mortice width. It works with any cutter that leaves a clean, repeatable kerf, such as saw blades or router cutters. As the readings are direct, there is no need for rules, calipers or any other measuring device, thus eliminating creeping errors.
3 simple steps to perfect tenons
1: Gauge the width of your specific blade kerf by using the distance between the orange slider and block.
2: Gauge the width of mortise by putting the protruding parts of the block and the dark slider into your tenon and lock in place.
3: Now use the orange slider and the block as a flip stop against your fence to achieve perfectly fitting, precise tenons.
This is a foolproof and accurate way to make tight fitting tenons. The TM-1 Tenonmaker works every time on tenon widths from 3-50mm.
The TM-1 Tenonmaker is 105mm x 38mm x 13mm; milled from solid aircraft grade aluminum and anodised for durability.
Specification
Specification
Model TM-1
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
