Chestnut Cellulose Sanding Sealer
Please note: You must be 18 or older to buy this product.
- Fast drying base coat prior to applying final finish
- Seals timber before applying wax finish for faster results
- Available in 500ml, 1ltr, 5ltr or 400ml aerosol
- N.B. To buy this product you must be aged 18 years or over.
36 Assorted Disposable Paint BrushesSpecial Price £13.98 £11.65 was £19.98 £16.65 Save £6.00 £5.00
A very fast drying sanding sealer by Chestnut for use as either a base coat for melamine lacquer or to seal the pores of the timber before applying a wax finish. Because of its relatively short drying time, it is often preferred by woodturners. A 400ml aerosol is now available but if brushes are used clean in cellulose thinners.
Application Method | Brush \ Rag or Cloth \ Spray |
Clean Up | Cellulose Thinners |
Coverage | 6 m² to 10 m² per litre |
Drying Time | 5 minutes |
Usage | Interior |
