Chestnut Shellac Sanding Sealer
- Clear finish, seals and fills wood pores
- Easily sanded to super smooth finish
- Used to seal prior to French or wax polishing
36 Assorted Disposable Paint BrushesSpecial Price £13.98 £11.65 was £19.98 £16.65 Save £6.00 £5.00
A clear easily sanded sealer, containing a high proportion of shellac. Slower drying than cellulose it is easier to apply to large areas, not such a problem to keep a wet edge. More suited to cabinetmaking, it also has special additives to prevent the shellac forming a hard lump in the bottom of the bottle. Use to seal prior to French polishing or applying fine paste wax.
Application Method | Brush \ Rag or Cloth \ Spray |
Clean Up | Methylated Spirits |
Coverage | 6 m² to 10 m² per litre |
Drying Time | 20 minutes |
Usage | Interior |
