Chestnut Tack Cloths
- A must use product after sanding and before applying finishes
- Picks up, removes and holds dust particles
- Reuseable over and over again, store in plastic bag
Axminster Professional Combination Square Metric 300mmSpecial Price ÂŁ14.98 ÂŁ12.48 was ÂŁ18.88 ÂŁ15.73 Save ÂŁ3.90 ÂŁ3.25
Tack Cloths are coated with a special, sticky resin. The resin doesn’t transfer off the cloth but when you wipe it across a surface it removes the fine dust particles that remain after sanding and which can have a detrimental effect on the final finish. Simply wipe over your work after sanding and before applying polishes. Multi-folded each cloth can be re-used many times, place in a plastic bag and seal after use. Not for use on lathe work with the lathe revolving. Supplied in packs of 3 or packs of 10.
