Tung is natural oil used extensively as the base of many finishing products and in its pure state as a heat and moisture resistant finish on furniture and fittings, worktops and table tops around the home and outdoors. Pressed from a nut, Tung Oil has been used for centuries in the Orient as a supremely resistant decorative finish for wood. Easily applied by cloth or brush, observing the instructions for the use of organic oils. Coverage: approx 6 - 8m/litre.
Coverage 6 m to 8 m per litre
Application Method Brush Rag or Cloth
Drying Time 12 hours
Clean Up White Spirit
Available Sizes 500 ml
Web Attribute Set Oil Finishes
EAN Barcode 5060095030424
