Chroma Craft Infil Stencils
From £18.98 £15.82 was £42.68 £35.57 Save £23.70 £19.75
  5. Half Star
7 Reviews
  • Helping create something special
  • Long-lasting, precision cut reusable stencils
  • Use alone or to enhance the Peel-Off stencil series
Ingenious woodturning tools
Tough, durable and razor sharp, the Crown Carbide Turning Tool range is a cut above the rest. Start turning straight out the box with Crown’s carbide tipped woodturning tools. The Crown Carbide range features solid tungsten carbide cutters, which are long lasting, tough and razor sharp.
The ultimate edge
The toughed cutting tips make the Crown Carbide Pro turning range highly efficient when turning wood, acrylic, polyester and resin. And with no need to sharpen, you can turn straight out of the box! When the carbide tips start to lose their edge, a simple sharpen will bring them back to life, or replace the tips when needed.
Controlled cutting
Each tool features a 20mm x 13mm shaft, made from super tough chrome vanadium steel, which helps smooth out vibration. The weight keeps the tool on the tool's rest and, combined with a 355mm long handle, ensures effortless control. The tools work best when flat and level, cutting at centre height or, with the handle slightly raised, cutting just below centre. The sides of the bar have a gentle radius allowing controlled shear cuts.
Fine Detail
Carbide Hollowing Tip
The Hollowing Tip Turning Tool has a 15mm diameter circular cutting tip, and is perfect for cutting coves in spindle work.
Carbide Roughing Tip
The Roughing Tip tool features a 15mm square cutting tip, and is great for removing material quickly. It is also capable of delicate refining cuts, flat or at a shear angle.
Carbide Detail Tip
The Detail Tip Turning Tool has a diamond shaped cutter, with 15mm long edges. The acute angle point is perfect for fine detailing, deep vee cuts, and the side edges are good for refining convex curves.
Chroma Craft Infill Stencils. Part of the woodturning artist Nick Agar’s Signature Series. Nick has teamed up with Chroma Craft from the USA, to create a series of stencils to share his decorating techniques.
This series of infill stencils are designed to create effects on their own, or used as a supplement to enhance the Peel-Off stencils.
Chroma Craft infill stencils are reusable so you can use them again and again.
The stencils can be used with any combination of techniques including airbrush, dauber or roller with dyes, paints and markers.
4.40 7
