Co-Matic QH03 Magnetic Base
- Designed for M3 Baby Power Feed
- No drilling holes required
- Measures 365 mm x 230 mm
- Easily movable between machines
The Co-Matic QH03 Magnetic Base is a versatile and convenient accessory designed specifically for the M3 Baby Power Feed. This magnetic base allows users to easily attach the power feed to various machines such as table saws, router tables, or small spindle moulders without the need for drilling holes. The base measures 365 mm x 230 mm, providing a stable and secure platform for the power feed. With its three powerful magnets, the QH03 Magnetic Base ensures a solid grip, and the magnets can be quickly activated or released with a simple handle mechanism. The maximum magnetic force is 450 kg and is suitable for use on materials of a maximum thickness of 40 mm.
This product is ideal for those who require flexibility in their woodworking setup, as it allows for quick and easy movement of the power feed from one machine to another. The Co-Matic QH03 Magnetic Base enhances the functionality of the M3 Baby Power Feed, making it a valuable addition to any workshop. Whether you are cutting grooves, mouldings, or batch cutting boards, this magnetic base provides the stability and ease of use needed for efficient and precise work.
EAN Barcode | 5052511136636 |
- Standard Delivery* - Free
