The Einhell TP-RO 1400 E Professional Router is a powerful and versatile solution for precise routing work in the workshop or garage. Equipped with a robust 1,400W motor, a variable no-load speed of 10,000-30,000rpm, and a generous 55mm plunge depth, it is ideal for demanding routing tasks, including work on hard materials and deep cuts.
The router features continuously adjustable electronic speed control, allowing the speed to be matched precisely to the material being worked on. Infinitely variable depth adjustment, complemented by a fine adjustment function, enables accurate and controlled plunging into the workpiece for high-precision results.
A stable double-tube guide system with solid guide bars provides excellent control and dimensional accuracy, while the multi-stage turret stop ensures consistent depth settings for repeated operations. The router is supplied with 6mm and 8mm collets, making it compatible with a wide range of router bits, and the integrated spindle lock allows for quick and straightforward cutter changes.
To help protect delicate work surfaces, the base plate is fitted with a plastic insert that prevents scratches and marks. The ergonomic design includes soft-grip handles and an optimised switch position for safe and comfortable two-handed operation. An integrated LED work light illuminates the cutting area for improved visibility, while the foldable chip breaker cover offers protection from flying debris. For a cleaner working environment, the supplied extraction adaptor can be connected to a compatible extractor (adaptor size 40mm outside diameter/35mm inside diameter).
Supplied complete with three collets (1/4, 6mm and 8mm), an open-ended wrench, compass tip, parallel guide, copy sleeve, extraction adaptor, and foldable chip breaker cover, the TP-RO 1400 E is ready for a wide variety of routing applications straight out of the box.
Collets Supplied 1/4, 6 mm and 8 mm
Spindle Lock Standard Feature
Sound Power Level LwA [Uncertainty K] 103 dB(A) [3.0 dB]
Corded or Cordless Corded
Cable Length 3 m
Sound Pressure Level LpA [Uncertainty K] 95 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] 4.4 m/s² [1.5 m/s²]
Motor Power 1,400 W
Cutter Speed 10,000 - 30,000 rpm
Manufacturer Part Number 4350560
EAN Barcode 4006825684414
