At 202mm long and with a weight of only 900g, the GWS 12V-76 EC Professional is both compact and lightweight. The handy size allows you to carry out work almost anywhere, even in sometimes hard-to-reach areas. Thanks to the EC motor, the GWS 12V-76 EC has a very high power output for its size. The 76mm diameter disc offers a maximum cutting depth of 16mm. This versatile cordless tool can cut a wide variety of materials. Discs are available for cutting metal, wood, plastics and ceramics, giving it plenty of scope in many different trades. It reliably cuts cable ducts, threaded rods and edge strips for tiles, as well as tiles and tile grouts, pipes, hollow profiles and even perforated bricks and parquet flooring. The motor is at 90
Supplied with 1 x carbide cutting disc and 2 x inox cutting discs. This is a body only machine and supplied without batteries or charger and part of the Bosch 12V battery family.
