The DeWALT DCS355N oscillating multi-tool uses the Quick-Change Accessory System allowing you to change blades and attachments without the use of tools.
The brushless motor at the heart of the tool delivers up to 57% more runtime compared to brushed motors. The dual-grip variable speed trigger provides complete control over the speed.
A bright LED light that illuminates dark work surfaces for accurate cutting. A universal accessory adaptor allows its use with most oscillating tool accessory brands.
This is a body only machine supplied with backing pad, 25 abrasive sheets, 2 saw blades and a blade adaptor.
Battery Voltage 18 V
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 97 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 86 dB(A) [3.0 dB]
Web Attribute Set Cordless Oscillating Tools
EAN Barcode 5035048440964
