The Axminster Magnetic Female Hose Coupler provides a dedicated machine-side connection point for Axminster magnetic dust extraction systems. Designed to work with the compatible magnetic male hose coupler, it creates a secure, self-aligning connection that allows a dust extraction hose to be connected and released quickly. Ideal for workshops where one extractor is shared between multiple machines, it helps reduce the time spent reconnecting hoses while maintaining an efficient dust extraction setup. Available in 63mm and 100mm sizes to suit a range of extraction systems.
Manufactured from durable workshop-grade plastic and fitted with a robust steel ring, the coupler is designed for reliable everyday use. It is typically mounted to a machine using a compatible rubber cuff or a short length of extraction hose, creating a permanent magnetic connection point ready for fast hose changes whenever required. Choose the size to match your existing dust extraction system.
Hose Diameter 63 mm
EAN Barcode 5052511147052
