Hermes
Hermes BW 115 Abrasive Discs 305mm
SKU: 910264
€6,95
  • Aluminium oxide abrasive on heavy E-weight paper backing
  • Semi-open coating, anti-static resin bonded reduces clogging
  • Hook and loop backing for easy disc changes
A range of 305mm diameter hook and loop backed sanding discs suitable for the Axminster Trade SS-12VS, Jet JDS-12 and previous model Axminster DS12VEL disc sanders.
The aluminium oxide abrasive on an E-weight paper backing has a semi-open structure with antistatic properties to reduce clogging. BW115 is especially suited to sanding hardwoods and is suitable for use on metal. It has a good stock removal rate even with low sanding pressure. BW115 is an excellent multi-purpose abrasive for use with powered sanders.
Available in a variety of grits. Sold in singles.
Abrasive Type VC 153 VEL
Size 305mm
Pack Quantity 1
Abrasive Grit 60
Abrasive Disc Diameter 305 mm
EAN Barcode 4047915749101
