Hermes
Hermes RB 377 YX Abrasive Belts 150 x 2,770mm
SKU: 508236
€23,00
  • Tough polyester/cotton cloth backed aluminium oxide abrasive
  • High stock removal rates in the coarse grit range
  • Consistent surface quality in the fine grit range
To fit Axminster Industrial Series 6 x 108 Belt Sander. The polyester/cotton back combined with the resin bonded aluminium oxide grain mix produces a high stock removal with course grits, plus a consistent surface quality with fine grits. Smooth running and long lasting, perfect for abrading metals and sanding seasoned woods.
Abrasive Type RB 377 YX
Abrasive Belt Length 2,770 mm
Abrasive Belt Width 150 mm
Abrasive Backing Cloth
Pack Quantity 1
Abrasive Grit 80
EAN Barcode 4050806913741
