The Axminster Pulsar Turbo Blower is an ingenious tool that you’ll find yourself reaching for often in the workshop. With an impressive maximum airflow of 58 m/s, the Turbo Blower is perfect for quickly cleaning tools down, blowing wood chips out of the way ready to vacuum, or blasting waste out of hard-to-reach areas. This high-speed air blower will prove useful in the workshop, in your car or van, as well as at home.
This handheld blower features a variable speed dial and brushless motor, meaning it can be used at full power when the need arises or be dialled down for more delicate tasks. Fully charged in approximately 2 hours, the Pulsar Turbo Blower has a continuous runtime of between 15-40 minutes, depending on the speed usage. Ergonomically designed at only 255g and measuring 160mm tall, it’s the perfect size for easy handling. It is supplied with two nozzle sizes, a USB C charging cable and a convenient storage case.
Part of the Axminster range, the Pulsar Turbo Blower is a tool of many uses which will earn its place in the workshop in no time. Its impressive air speed can move even difficult dust or debris, while giving you the option for a softer air flow, all in a pocket-sized, rechargeable tool.
