The Fiskars PowerGear™ X Tree Pruner is designed to give gardeners exceptional reach, precision and control when cutting fresh wood in hard‑to‑access areas. Its adjustable shaft extends from 2.4 to 4 metres, providing a maximum vertical cutting reach of up to 6 metres, allowing you to trim branches safely from the ground without the need for a ladder. A 230° adjustable cutting head makes it easy to approach branches from any angle, ensuring cleaner, more controlled cuts when working high overhead or deep within dense growth. Suitable for cutting fresh wood up to 32 mm in diameter, it delivers the strength and efficiency needed for routine tree and shrub maintenance.
Engineered with PowerGear™ technology, the pruner increases cutting force where it’s needed most, helping you slice through thicker branches with less effort. Durable SoftGrip™ handles provide comfort and a secure hold, while the non‑slip base and bright orange cutting support enhance visibility among foliage. The lightweight construction keeps the tool manageable during extended use, reducing strain while improving reach and control across all height levels.
With over 375 years of design heritage, Fiskars is known for creating tools that combine high performance with ergonomic excellence. Their cutting tools are trusted worldwide for their durability, precision and comfort, making them a preferred choice for gardeners seeking efficiency and long‑lasting quality.
The Fiskars PowerGear™ X Tree Pruner is ideal for maintaining tree crowns, trimming high branches, managing dense shrubs and performing detailed pruning work without bending, kneeling or climbing.
Specification
Cutting Capacity: 32 mm
Length (Shaft): Adjustable 2.4m – 4 m
Maximum Reach: Up to 6 m including the operator’s arm
Weight: 1,900 g
Cutting Head Adjustment: 230° rotating head
Intended use; long‑reach professional pruner, meant for tree crowns, high branches, and dense overgrowth, no ladder needed.
Web Attribute Set Pruning
EAN Barcode 6411501150127
