The Roughneck® Square Point Shovel is strong yet lightweight, with a fully hardened pressed steel construction. Treads on the blade allow for increased pressure to be applied with reduced risk of slippage. The Power Ring socket, steel reinforced plug, provides stronger blade to handle connection. It has a fibreglass shaft for reduced overall weight, with a comfortable, double-injected D grip handle. Ideal as a general-purpose shovel for moving sand, gravel, cement, earth and for shovelling out and filling trenches.
Specification
Blade Width: 215mm
Overall Length: 1,067mm (42)
Web Attribute Set Builder's Shovels
