Supplied in matched pairs these hardened and ground Vee blocks are accurate enough for use in layout work and robust enough to be used in machining operations. Dimensions are: 37 x 37 x 50mm.
Axminster Engineer Series Vee Blocks and Clamps
| Overall L x W x H | 37 mm x 37 mm x 50 mm |
| Web Attribute Set | Vee, Gauge Blocks & Angle Plates |
| EAN Barcode | 5052511010424 |
