The Axminster Ultimate Marking Set brings together three precision layout tools in one convenient package, providing woodworkers with a comprehensive solution for measuring, marking and transferring dimensions accurately. Whether you're laying out joinery, marking cut lines or setting precise angles, this carefully selected combination of tools helps improve consistency and accuracy throughout the woodworking process. Suitable for both workshop professionals and serious enthusiasts, the set offers versatility across a wide range of woodworking applications.
All three professional marking tools are engineered in stainless steel for wear resistance, with clearly identifiable scales and micro-fine marking holes every 1mm for exact placement. They are all supplied with a mechanical pencil and refills for added convenience, so there will always be a precise pencil to hand.
The Axminster Angle Rule is designed to simplify accurate marking from an edge or reference face. Its versatile design allows users to mark parallel lines, transfer measurements and create repeatable layouts quickly and precisely. Ideal for furniture making, cabinet construction and general woodworking, it helps eliminate common measuring errors while speeding up setup and marking tasks.
The Axminster T-Rule 400mm provides a reliable method for marking perpendicular and parallel lines with exceptional consistency. The extended 400mm scale offers excellent reach for larger workpieces, while its precision layout features make it ideal for dimensioning panels, marking centres and establishing accurate reference points before cutting or assembly.
The Axminster Marking Protractor enables fast and accurate angle layout across a broad range of woodworking projects. Designed for setting out and transferring angles with confidence, it is particularly useful when working on mitres, compound joints, angled components and bespoke furniture projects where precision is essential.
Axminster's Measuring & Marking range is developed to meet the demands of modern woodworking, combining practical design with dependable accuracy. Trusted by makers, joiners and furniture craftsmen, these tools are engineered to support precise workmanship and help achieve consistently professional results in the workshop.
