Thor dead blow hammers have coated die-cast aluminium alloy head with rubber grip and screw-in faces. The hollow die-cast head is partially filled with steel shot to add to the weight, prevent rebound and deliver dead blows of maximum force. Thor dead blow hammers are ideal as a multi purpose striking tool and are ideal for sustained and effective blows without recoil. They are commonly used in most assembly / fitting applications including engineering, toolmaking, shopfitting, partitioning and double glazing. Replacement faces are available.
Thor
Thor 2020 Dead Blow Nylon Hammer - 63mm, 1,850g
| Hammer size \ weight | 63 mm - 1,85kg (4lb 2oz) |
| Web Attribute Set | Soft Faced Hammers |
| EAN Barcode | 5012936202019 |
