The PROXXON FSB240/E is perfect for jewellers, mechanics, model builders, opticians, electronic enthusiasts and professionals. Can be used for prolonged periods when drilling, milling, die grinding, polishing, cleaning and engraving. This 100W multi-tool has a keyless chuck (0.3-3.2mm) to accept a wide range of accessories, well balanced and with variable speed for maximum control. The tool is well designed and the two inset rubber grips on the body ensure a good purchase, important for fine detail work. The permanent magnet motor is powerful and well balanced and the variable speed control gives a range of 5,000 to 20,000rpm. At the opposite end to the drill chuck is a hanging loop, used when the tool is coupled up to a flexible shaft. This tool has a quality specification, a flexible drive shaft with precision handpiece and 1.0mm, 2.4mm and 3.0mm collets is also available as an optional extra. Supplied in a plastic storage case with 43 cutting, grinding, drilling and sanding accessories.
Rating Trade/Professional
Corded or Cordless Corded
Chuck Capacity 0.3 mm to 3.2 mm
Chuck Type keyless
Sound Pressure Level LpA [Uncertainty K] 70 dB(A) [3.0 dB]
Motor Power 100 W
Web Attribute Set 230V Rotary Multitools
EAN Barcode 4006274284722
