A quick drying pigmented acrylic lacquer to give the smooth luxurious look of Ebony in a hardwearing satin black coat. After good preparation apply either Chestnut's Acrylic or Cellulose Sanding Sealer as per the instructions. When this has dried thoroughly apply several thin coats of the Ebonising Lacquer at ten-minute intervals. This will be touch dry in ten minutes but should be allowed 24 hours to cure fully before use or further enhancement with Chestnut Acrylic Gloss Lacquer.
Coverage 6 m to 8 m per litre
Application Method Spray
Drying Time 20 minutes
Size 400ml
Web Attribute Set Lacquer, Paint & Varnishes
EAN Barcode 5060095030271
