Drawer pull cutters offer the opportunity to create flush fitting cabinet doors and drawers and are easier to use if used in a router table set-up. Drawer pull cutters remove the need to have protruding handles on your cabinets.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
D = Overall Diameter 44.5 mm (1.3/4")
R1 = Radius 1 6.35 mm (1/4)
R2 = Radius 2 3.2 mm (1/8)
D 44.5
R1 6.35
R2 3.2
X 29
Shank Diameter 1/2" (12.7 mm)
X = Depth of Cut 29 mm
X = Depth of Cut 28.6 mm (1.1/8")
D 44.5
R1 6.35
R2 3.2
X 28.5
EAN Barcode 5052511030675
