Axcaliber
Axcaliber Finger Joint Cutter
SKU: 666228
€65,00
  • Produces an incredibly strong joint with large gluing area
  • Join boards end to end or edge to edge
  • SAE4140 steel shank hardened to Rockwell 45 HRC
  • Diamond ground micrograin tungsten carbide tip
  • Virtual mirror finish ensures durable, clean cutter
  • PTFE coating helps cutter to remain free of resin
  • This cutter is for use in router tables only
The extra gluing area produced by using this cutter makes for an incredibly strong edge to edge joint. With a maximum cutting depth of up to 38mm, most board thicknesses can be accommodated. Recommended for router table use only.
Shank Diameter 1/2" (12.7 mm)
X = Depth of Cut 38 mm (1.1/2")
D = Overall Diameter 35 mm
Web Attribute Set Jointing Router Cutters D: 35 X: 38
EAN Barcode 5052511030682
