A high quality range of twin flute 1/2(12.7mm) shank cutters available in metric and imperial sizes the metric having a bottom cut insert for improved plunge cutting. The larger shank of these cutters helps eliminate vibration and chatter under load and if your router will accept a 1/2(12.7mm) collet these cutters are are a good choice for many different applications.
Shank Diameter 1/2" (12.7 mm)
X = Depth of Cut 25 mm
D = Overall Diameter 12.5 mm
D 12.5
X 25
EAN Barcode 5052511125890
